transmission
Old Jun 26, 2006 | 03:11 AM
shark79's Avatar
Default transmission
Has anyone converted there automatic transmission into a standard? If so about how much, and how hard was it?
Old Jun 26, 2006 | 09:21 AM
Default RE: transmission
Well, you have to have a set of pedals, linkage, bracket for frame, pivot on engine block, bell housing, clutch assembly, cross member, and of course, transmission. Some cases might require driveshaft modification. If you have the transmission already, you might spend another $500.00 on additional parts if you do the work your self. Might have to change out some of your console, also.
Old Jul 29, 2006 | 12:21 AM
BB72's Avatar
You almost got all of the conversion down....don't forget the pilot bearing in the crank. Sometimes frames don't have the mount for the outside end of the pivot linkage. You can buy that cheap enough and weld it on. I'm doing the same thing right now. You need a separate mount for the tranny and the shifter unless you use a muncie which the shifter mounts right on the tranny. Those mounts should bolt right up to a previously auto crossmember. Plug your tranny cooling lines at the rad, rip out your auto shifter, buy a manual shifter, flywheel, clutch... mount your pedals ......lots of stuff, it's not cheap. It's a big job but I think it's worth it. Mine(1972) was apart getting a frame off and thought why not convert. Good luck.
jeremo
Jan 10, 2023 05:51 PM
t88supra
Aug 8, 2006 05:38 PM
LLL
Dec 16, 2005 07:34 PM
vette86
Sep 4, 2005 01:47 PM
mlm66
Jul 7, 2005 04:39 PM
