transmission problem!! ! ! HELP!!
Old Apr 13, 2007 | 01:09 AM
imjustsean's Avatar
Default transmission problem!! ! ! HELP!!
ok so check it out! my 77 is havin some problems! i bought a b&m shiftkit for it and installed it exactly like they said. but i dont have a reverse and the car tops at like 2500 rpm, like it has a problem shifting. . . . not good!!! and whats the trick to adjusting an edelbrock carb? its a 600 performer series. so yea other than that its a dream, exept the interior. haha
Old Apr 13, 2007 | 10:01 AM
Default RE: transmission problem!! ! ! HELP!!
Sounds like you have the shift pawl out of adjustment. You have a turbo 350 or a 400?
Old Apr 13, 2007 | 08:35 PM
78buckshot's Avatar
Can't help with the tranny problem but the last Edelbrock I went through tuned pretty easy, you can order the jets, metering rods and other tune up parts from them.
Old Apr 13, 2007 | 11:56 PM
imjustsean's Avatar
yea its a turbo 350, i fixed the "main" problem but still no reverse...and under the hood right next to the throttle cable, is another cable...it looks like it connects to the same side as the throttle cable so....i dunno! help please!!
Old Apr 14, 2007 | 09:57 AM
78buckshot's Avatar
The other cable next to the carb is the transmission kick-down cable, you'll need to attach that to the bellcrank that the throttle cable is on but on the bottom of the bellcrank, the results that you want is when you open the throttle with the pedel the trans cable is being pulled, this kicks the tranny into "passing gear" when you get on it.
Old Apr 14, 2007 | 05:20 PM
imjustsean's Avatar
neato... but still no reverse! does anyone know what the other 2 check ***** in the tranny are for? cause the instructions told me to remove all but one..so i'm thinking that might be it.
oh and what it the kick down cable is ALWAYS pulled...what would that do...?
bctisme
May 7, 2015 06:45 PM
svt04cobra
Corvette C5 Z06
Jan 21, 2009 06:23 PM
Rickcusaf
Dec 28, 2008 07:04 PM
vette86
Sep 4, 2005 01:47 PM
mlm66
Jul 7, 2005 04:39 PM
