"85 clutch question
The switch is high up above the clutch pedal. It is very hard to get to. Once you find the connector, disconnect it and place a jumper to bypass that switch. All your starting troubles will be over...of course just remember that the starter will then operate when the clutch is not depressed. BTW that safety switch is no longer available anywhere. Good luck.
