LT1 & Clutch Question
Old Dec 8, 2006 | 03:57 PM
ernie22golf's Avatar
Default LT1 & Clutch Question
How much of a lumping idle does a true stock LT1 - 1995 variety have? Mine seems to lope pretty good at idle but calms down as rpm's go up quickly. On the clutch it engages right at the top of the clutch petals travel. I checked the fluid in clutch master cyl and it is full. Is this normal - last clutch was approx 1 or 2 inches before petal fully out.
Thanks
Old Dec 8, 2006 | 11:12 PM
Default RE: LT1 & Clutch Question
Any factory LT1 I've ever heard has a smooth idle. If your clutch pedal is at the top, more than likely your clutch disc is wore out. [8D]
Old Dec 11, 2006 | 12:27 AM
86 Ironhead's Avatar
Clutch is bad or the pressure plate is bad. Either way the tranny has to be dropped and the bell housing removed. If the problem was the clutch master or slave cylinder your symptoms would be reverse....the clutch would disengage at the bottom of the pedal.
Figure 700-800 in labor to remove and replace and $250 parts (clutch/pressure plate/throw out bearing)
Chris
Old Dec 11, 2006 | 01:30 PM
Thanks for the info,
Can driving hurt - it's a tough time to shell out the funds currently - I don't really drive much - I kind of thought that might be the problem but was hoping not the case. I haven't noticed any slipping of clutch but I'm sure that is coming or currently happening. Would driving somewhat hurt flywheel or transmission?
Thanks
Old Dec 11, 2006 | 03:13 PM
You can drive it until the clutch shatters. Then your dead in the water. Try to stay away from hills, and stopping in heavy traffic. I'd say you have about 350 miles before it just slips completely (no movement).
Old Dec 11, 2006 | 04:01 PM
Thanks for heads up,
what brand clutch & pressure plate would you recommend?
did you replace the flywheel?
Thanks
cedarsales
Apr 9, 2014 07:21 PM
santaman58
May 13, 2007 10:25 AM
texas_outlaw93
Jan 9, 2007 07:12 PM
mercedes84black
Dec 8, 2006 01:36 PM
mercedes84black
Jun 17, 2006 03:42 PM
