1984
I've read about the attempts of the TPI's and read that it takes much carefull work to get them to do as good as a big carb! the crossfire concept is like all those that want TOP power for racing but needs attention: all the hours that the factory didn't do!
About the only people who bad mouth the 84 are those that never had one. There is absolutely nothing wrong with CFI, it was used on several other GM cars. Its quite reliable and I havent had a problem in the 18 years I've owner the car. The only downside is that the intake is not easily upgraded for power. However, low range torque is quite superior to TPI cars. An 84 with a decent exhaust rivals HP of an stock 85 TPI but with better low range torque. However, I do LOVE how the tpi looks...best engine aesteticly in MHO.
I'd say the major reason not to buy an 84 is all the bloody squeaks and rattles, especially on a Z51 car. They can however be eliminated. I have a 28 page TSB on my site for those issues.
Choice is relative based on what you find. I'd certainly go for a low mileage 84 with good paint over an 85-87 with worse paint since thats a few grand to do it "right".
Another choice is what dash you might want...the digital or the later anolog/digital speedo c4 design.
Id set a high and low budget and go from there.
PS If you want an UGLY Vette...by all means buy a c5 :-D~
Let me weigh in just a bit. Rule ! when buying a vette. Never believe the odometer. That is extra true with 84 to 90s. The odometer can be replaced in under an hour. I owned a brand new 1984. Wanted it so bad I paid a dealer's finder fee. They were hard to get when they first started hitting dealers lots. It was a fantastic car (Z51) far better than the 81 I traded on it. Don't believe those odometers either. takes about 5 minutes to disconnect the cable and run on the tach. Anyway the cross fire only hasted two years. They were put in the 82s which were C3s and then the 84s. There were no 83s. The 84 has the stiffest suspension of any of the C4s Or at least any of the standard or Z51 or Z52 models. And I think it handled great. You can run over a quarter and feel of it's heads or tails
, well almost. You sound like the car is not for sale but you want to make an offer anyway. In that case you will probably have to go big. But as someone said the 84s are not real popular so $4000 sounds like a fair starting point for you, not for the seller. If the mileage is true and the seller knows it is he will push back. Again, don't trust the odometer, look at the drivers seat, the brake pedal and door strikers. Look carefully under the hood. A low mileage garage kept car should not look worn at all.
Your Welcome. I appreciate replying to my post.
We are all here to share information about corvettes. I am always learning and appreciate info of info about corvettes that I may not know.
keep the communication going.
Have a safe and great Vettetopia weekend.
Vette84
May 2, 2007 08:50 AM
