1991 C4 won’t start
Old Jun 27, 2023 | 10:20 AM
Mhines5's Avatar
Default 1991 C4 won’t start
My 1991 corvette won’t start. How do I know whether this is a VATS issue or something else?
Old Jun 27, 2023 | 05:03 PM
Welcome to the forums, check the fuses (all of them, ign, fuel pump, ecm) first to make sure you don't have a bad one, if you haven't already. Pull a spark plug wire and check for spark. Check the fuel system to see if you can hear the fuel pump when the key is turned on, and has fuel pressure, and for injectors use a 12v test light and see if the injectors are getting power. Doing this while turning the engine over. That should get you going in the right direction..
Sparta49
Oct 17, 2022 11:33 AM
RBarber133
Sep 19, 2021 03:13 PM
dhansen
Jan 27, 2020 12:34 AM
elgamax
Feb 9, 2009 07:34 PM
giacc
Sep 17, 2006 08:54 PM
