Pin won’t come out
Old Jun 30, 2023 | 07:45 PM
Broffermoon's Avatar
Default Pin won’t come out
Replacing the gear mechanism on 1994 basic corvette headlight. Exhibits the classic symptoms of a stripped gear or smashed cylinders. Got the unit off and set on the work bench. Tried to remove the pin holding the gear shaft to the frame. It would not budge. Took a pin punch 5/32 and gave it a good hit, did not move . Can you help me remove the pin? Sprayed on penetrating oil, still nothing. What have you done that worked?
Old Jul 1, 2023 | 06:00 AM
Welcome, have you looked at youtube to see if anything relates there?
Old Jul 1, 2023 | 08:12 AM
Default Wrong wording
I had looked all over but apparently using the wrong key words. With your help I was able to clearify my requests. Got it, common problem, several solutions o clouding boring the thing out. Thanks.
Old Jul 1, 2023 | 05:28 PM
Default Surprise!!
Walked by the workbench and the pin was nearly out. How? I don’t know it a light rap from a pin punch and bingo!! Repaired the headlight. The gear was near perfect but the cylinders were trash. Replaced the cylinders and put it back together. Works great. Nice to have this resource as we bro g this 1994 back to original. Thanks again.
Old Jul 2, 2023 | 06:14 AM
I'm glad it was an easy fix..
apeaton
Jan 20, 2021 11:37 AM
braveheart3158
Jul 29, 2013 12:24 PM
bobslsc
Mar 21, 2013 04:32 PM
wwbvette
Sep 24, 2007 07:26 PM
vettemanrob
May 30, 2006 10:24 PM
