1995 Corvette Reverse Lights INOP (6sp base)
This is an issue since before I bought the car and its time to address it. Obviously new bulbs didnt work, and when in reverse the connectors in the back have no juice. What areas should I check next?
Start at the switch and see if it has power and, if it does, ensure that it is passing it on.
Last edited by 73shark; Jul 16, 2023 at 10:30 PM. Reason: Eliminated the gibberish at the beginning of the sentence. 😟
You are lucky it's not intermentent they are the hardest to locate. Good fuse? Good ground at the bulb socket? with no power at the bulb socket? Check the back up switch for power. not sure what transmission you have auto or man. the switch should be on the trans. check it's operation. Good luck
