1995 Corvette Reverse Lights INOP (6sp base)
Old Jul 16, 2023 | 02:15 AM
Silverspoon's Avatar
Default 1995 Corvette Reverse Lights INOP (6sp base)
This is an issue since before I bought the car and its time to address it. Obviously new bulbs didnt work, and when in reverse the connectors in the back have no juice. What areas should I check next?
Old Jul 16, 2023 | 12:11 PM
Start at the switch and see if it has power and, if it does, ensure that it is passing it on.
Last edited by 73shark; Jul 16, 2023 at 10:30 PM. Reason: Eliminated the gibberish at the beginning of the sentence. 😟
Old Jul 16, 2023 | 05:27 PM
Originally Posted by 73shark
House and they didn't start at the switch and see if it has power and, if it does, ensure that it is passing it on.
Im not following...
Old Jul 16, 2023 | 06:45 PM
You are lucky it's not intermentent they are the hardest to locate. Good fuse? Good ground at the bulb socket? with no power at the bulb socket? Check the back up switch for power. not sure what transmission you have auto or man. the switch should be on the trans. check it's operation. Good luck
Old Jul 17, 2023 | 12:50 AM
There are a couple of places for me to start with. Thank you!
SCHOON
Mar 20, 2012 06:11 PM
Dec 19, 2007 12:54 PM
timcole69
Dec 5, 2007 11:56 AM
jblack66
Oct 6, 2007 06:33 PM
mercedes84black
May 18, 2006 12:03 PM
