84 bogging on accelleration, not drivable
Old Aug 28, 2013 | 06:12 PM
swa513's Avatar
Question 84 bogging on accelleration, not drivable
hi, my 84 has been sitting for a few months & im trying to get it going again. it will start and idle fine, and you can rev it up and it revs fine in neutral but, when you get out on the street it falls flat on its face. it runs kind of like the choke is still on. so far i have checked the wires (about 3 years old), plugs only have about 1000 miles on them. i put a new tps & map sensor on it, pulled the ecm out and checked for cracked solder joint & it looked fine. vaccum is about 19-20lbs, i pulled the fuel pump (about 5 yrs old & an 85'), cleaned the pickup strainer & put in fresh gas. changed the fuel filter, and rebuilt the injectors they look like they have a nice steady flow on both tb's. i have oxygen sensors & a new egr on its way. is there something else i should be checking out? i was thinking of ordering a new spark module & ignition module. im thinking its not a fuel issue because you can rev it up when its parked and it is getting plenty of fuel.
95C4yourself
Nov 18, 2008 12:40 PM
scuba steve
Jun 3, 2007 10:41 PM
Zanador
May 28, 2007 09:10 PM
deansreef
Mar 23, 2007 11:56 PM
