84 crossfire heater ?
Old Apr 26, 2007 | 09:22 PM
morgans762's Avatar
Default 84 crossfire heater ?
How do I gain access to the valve that switches from hot to cold air. Mine is not closing all the way. I know its under the dash, but could you guys point me in the right direction. Thanks
Old Apr 27, 2007 | 12:16 AM
Default RE: 84 crossfire heater ?
1st, is your car manual a/c or does it have climate control? Manual a/c uses a cable that attaches to a lever under the passenger side. You have to remove lower trim cover to see it. You will have to lay on your backside and get really contorted to see it, but if you can, then you can watch the operation by sliding the temperature lever back and forth to see if it is moving. Climate control uses a vacuum control module (programmer) than routes vacuum to different valves based on inputs it receives from the a/c control head. Very seldom have seen vacuum valves go bad, it usually is the programmer and sometimes the control head.[8D]
Old May 4, 2007 | 12:17 AM
morgans762's Avatar
I checked the cable and it is opening and closing properly. I still have hot air coming out the floor with it set on cool and turned to the off position. When I switch to vent I still get hot air. Any other ideas? Thanks.
towerop
Aug 10, 2006 09:25 PM
Zero Limits
Aug 8, 2006 05:13 PM
charlesn
Jul 30, 2006 09:34 PM
froggy3
Jul 18, 2006 09:36 AM
placidthree
Oct 13, 2005 03:13 AM
