84 vette starting and fuel issues
Old Apr 23, 2007 | 11:39 AM
  #11
Vette ZX6's Avatar
Default RE: 84 vette starting and fuel issues
It definitely sounds like an ECM problem. I assume that since you said if you poured fuel into the throttle body the car would run, that means you are gettingspark.One other thing to look at, does the check engine light come on when you turn the key to run? If not then it indicates an ECM problem also.
Old Apr 23, 2007 | 02:45 PM
  #12
tmask84vette's Avatar
Yes I do have spark. When I pour fuel direct into the throttle body it tries to run. I will have to check on the "check engine" light. I do not recall seeing it light up. I really appreciate the help and direction. Once I get an ECM, I will let you guys know if it fixed the problem. Again, THANKS!
Old Apr 25, 2007 | 09:41 AM
  #13
Replacing the ECM did the trick!!! Thank you very much for the help and direction.
Now I can get busy with the other issues I have. I am sure you will here from me again. I can't tell you how much I appreciate the help from both mech259 and vette ZX6. It felt good to drive it around the block!
Old Apr 25, 2007 | 06:52 PM
  #14
Great! [sm=badbadbad.gif][sm=gears.gif]
Old Apr 26, 2007 | 12:43 AM
  #15
always glad to hear about a solved problem. Have fun with it and run the crap out of it.
ewrobo
Aug 13, 2008 01:01 AM
red90vettesc
Aug 6, 2007 02:57 PM
red90vettesc
Mar 15, 2007 11:17 PM
95trplblkandtan
Jan 9, 2007 03:06 PM
mercedes84black
Jun 24, 2006 09:30 PM
