85 headlight problems
Old Sep 18, 2007 | 10:28 PM
wwbvette's Avatar
Default 85 headlight problems
My 1985 corvette coup drivers headlight will not come up when lights are turned on,but when you manual put headlamp up and turn switch off light will go back down can anyone help me troubleshoot this problem . Is it a relay or plastic gears in motor
Old Sep 23, 2007 | 02:10 PM
Default RE: 85 headlight problems
Sounds like the 'screw' gear, which turns the 'wheel' gears. It has 'play' in it, by design, so that at the end of the light rotation, when it can't rotate any more, the 'screw' gear moves upward (or downward), to make an electrical contact and stop the turning of the screw gear.
Confused? It was explained differently recently - ya' just gotta' find the other post.
Old Sep 24, 2007 | 06:55 PM
wwbvette's Avatar
Found the problem it was the small contact in the motor that was not making contact straghten out and it works but will have to buy new motor not sure how long it will last
Old Sep 24, 2007 | 07:26 PM
ORIGINAL: wwbvette
You mean the shut-off contact of the worm gear like shiver was describin'? Got a pic?
I gotta pull mine tomorrow or the next day or so...
g.wichman29
Jul 12, 2012 12:01 AM
slovette
Technical Diagram Help
Apr 12, 2011 07:16 PM
dthompson20616
May 8, 2010 07:44 PM
flyinc5
Mar 20, 2010 07:24 PM
rdn2113
Oct 20, 2006 09:34 AM
