85 VETTE GAS PROBLEM
Old Oct 16, 2006 | 02:34 PM
GREENSKIN's Avatar
Default 85 VETTE GAS PROBLEM
HI I HAVE A 85 VETTE I RECENTLY PUT A NEW FUEL PUMP N FILTER MY PROBLEM WHEN FUEL GET TO ABOUT HALF EMPTY WHEN I HIT A SHRP TURN IT IT WILL SUNDDELY STOP RUNNING UNTILL YOU GET STRITE OR OFF THE THROTTEL THEN IT KICKS IN HARD SEEMS LIKE THE GAS IS ALL GOING TO ONE SIDE OF TANK FOR A SPLIT SEC. OR IS THIS SOME KIND OF SAFTY FEATURE I REPLACE ALL FILTERS I NOTICE IN TANK THE FUEL PUMP FILTER HAS A TALL END AND SHORT END I NOT SURE WICH WAY IT IS SOPPSE TO BE I PUT THE TALL END OF FILTER UP ANY HELP ON THIS I APPPERCAITE THANKS
Old Oct 16, 2006 | 03:40 PM
All2kool's Avatar
Default RE: 85 VETTE GAS PROBLEM
Three things - what is 'strite'? Second - the Fuel Filter will BE CLEARLY MARKED AS TO FLOW DIRECTION. And thirdly - SPELL CHECK!
Old Oct 17, 2006 | 12:06 AM
GREENSKIN's Avatar
OK i cant type lol i know that. i will check the fuel filter just to make sure of the flow stright ahead it runs fine wide open hard conering it dies for a sec unless tank is completly full .... i think i spelled everthing correct this time lol
Old Oct 17, 2006 | 12:23 AM
94blackC4's Avatar
ORIGINAL: GREENSKIN
Haha, Not quite... But who cares right?
Old Oct 17, 2006 | 08:50 AM
mypetu39's Avatar
All2Kool, I had the same problem with his thread...
mypetu39
Old Oct 17, 2006 | 09:31 AM
Did you put the strainer on at the right angle? Facing front to back. Also, you might have a baffle that came loose in the tank, if so it's tank replacement time. []
Old Oct 17, 2006 | 01:59 PM
GREENSKIN's Avatar
yea i not a good typer lol but thats not my problem rite now lol the baffel is the littil box in the tank that the fuel pump sits in if so it is not broke it is solid. now the strianer is on the end of the fuel pump? i think it is the strianer itself is offset if you have the pump out and put the strianer on it has a long side to it i dont know were the long side should point to if the pump is bolted back to the car and sitting in baffel should long side be up or down i think downwards it would smash against the bottom of baffel
see when i changed pump the strianer was all ready off laying in tank so i have no way of knowing wich way it the long side faces i not sure what you mean there facing front to back theres no marking on strianer
chuck
Mar 7, 2010 05:42 PM
wilton
Aug 30, 2009 05:32 AM
leitzpower
May 18, 2007 05:53 AM
reactor2
Sep 4, 2006 09:33 PM
john
Sep 3, 2005 03:48 PM
