86 Vette question
Does anyone know the color of the wire(s) and voltage for the Fan Switch that is located between #1 & #3 cylinders just below the header? The PO replaced the engine and didn't connect the switch.
thanx
thanx
If thats the case, what is the sensor under the manifold at #8 cylinder? Neither of these sensors had wires on them when I bought the car and when I connected the sensor at #8 (dull red wire), i started to see temperature readings on the dash.
right now, I have two wires on the drivers side near the sensor. (1) is black w/12V with the ignition key on, the other is dark green with no voltage.
