86 Vette question
Old Jan 3, 2007 | 10:17 AM
rwolak's Avatar
Default 86 Vette question
Does anyone know the color of the wire(s) and voltage for the Fan Switch that is located between #1 & #3 cylinders just below the header? The PO replaced the engine and didn't connect the switch.
thanx
Old Jan 3, 2007 | 02:18 PM
Default RE: 86 Vette question
Actually, that position is where the temp sender goes for the gauge on the dash and it is one wire that is dark green.[8D]
Old Jan 3, 2007 | 06:06 PM
rwolak's Avatar
If thats the case, what is the sensor under the manifold at #8 cylinder? Neither of these sensors had wires on them when I bought the car and when I connected the sensor at #8 (dull red wire), i started to see temperature readings on the dash.
right now, I have two wires on the drivers side near the sensor. (1) is black w/12V with the ignition key on, the other is dark green with no voltage.
ednev
Feb 10, 2012 02:08 PM
dudley
Sep 6, 2008 10:16 PM
BluBeaSSt
Jan 24, 2007 09:53 PM
Clayton
Oct 14, 2005 01:12 PM
heavychevy
Sep 9, 2005 12:10 AM
