87 Tail Light ground
Old Jun 9, 2009 | 12:32 AM
Catman87's Avatar
Default 87 Tail Light ground
Anyone know where the tail lights ground on an 87 coupe? I think they have lost their ground and may be trying to ground thru the turn signal indicators. I have traced some of my digital dash problems to the headlight switch,which I have replaced, but has gone bad too, and am going to replace again, this time I'm not using the AC Delco. I am thinking the taillights and the headlight switch problems are connected with the dash. Thanks for any help you may be able to give.
Old Jun 9, 2009 | 06:04 PM
SteelBlue91's Avatar
On the convertible, I *think* (this is from memory) that the ground for the taillights is on the "wall" behind the passenger seat. You have to lean the passenger seat forward and pull up the carpet starting at the rear in front of the trap doors, below the courtesy lights (which have to be removed). This carpet folds over the ridge and you can feel the ground on the front side of the "wall".
If you want to test a direct ground, you should be able to get to the wiring through the hole behind the license plate.
Hope this helps... this is for a convertible, but I think the coupe is the same/similar. This is also from memory and my own experience on my 91 (should be the same).
SB91
Old Jun 10, 2009 | 09:30 AM
Gromit's Avatar
Default Had the same problem
I had the same problem you describe on my '93. After an incredible amount of troubleshooting and tracing wires, I found that the problem was some corrosion in a male/female connector that was located on the side of the right-hand (passenger side) wheel well under the carpet. I cleaned and scraped the contacts and it cured the problem, but it was really hard to find.
Gromit
Power$elling
Jan 15, 2007 04:26 PM
POLO GREEN 90
Nov 26, 2006 11:23 AM
mercedes84black
Jun 28, 2006 09:56 AM
Kyle93
Mar 20, 2006 06:58 PM
Wrangler47
Mar 3, 2006 09:33 AM
