93 c4 lti won't start.
Old Mar 17, 2008 | 02:50 PM
wldbill's Avatar
Default 93 c4 lti won't start.
Ok I have a problem w/distributer acording to codes have narrowed down to bad distributer or bad connecter. Just b4 vehicle wouldn't start noted dripping from water pump area could this mean remove distributer cap and rotor dry out dolve problem or is a replacement of entire distributer necessary? I have not even started to remove distributer, as it appears I must remove waterpump also. Is it possible to remove cap w/o removing waterpump? Do you also need to pull harmonic balancer to remove distributer?
Old Mar 17, 2008 | 03:07 PM
LeesVette's Avatar
Default RE: 93 c4 lti won't start.
Your going to have to remove a lot more than the water pump to get at the Optispark distributor. If you have had coolant leaking on the Opti then more than likley (which might as well be definetly) your going to need to replace it. Not just do a cap and rotor. You might as well put a new water pump on why your there. Now would also be a good time to to the plug wires too.
Old Mar 17, 2008 | 05:36 PM
wldbill's Avatar
I have 41000 miles on it just replaced plugs and wires, just as I thought probably replace w/p and hoses while pump is off. Primary concern is there room to replace w/o pulling harmonic balancer.
Old Apr 21, 2008 | 04:09 PM
502scs's Avatar
ORIGINAL: LeesVette
+1
Old Apr 29, 2008 | 10:23 PM
92LT1's Avatar
You can pull the Distributor with out pulling the balancer...
Rick854
May 2, 2006 01:28 AM
buckeyevette
Mar 22, 2006 11:45 PM
Barry
Mar 12, 2006 03:05 AM
raisinbran
Dec 17, 2005 02:48 AM
PHILC
Nov 20, 2005 11:18 PM
