94 auto stuck in ppark
Old Mar 2, 2020 | 10:58 PM
KTM rdr's Avatar
Default 94 auto stuck in ppark
My "94" transmission shifter is stuck in Park. Looking for some suggestions as to where to start looking for the problem.
Old Mar 3, 2020 | 09:30 AM
I seem to remember hearing that there is an interlock solenoid that may be the problem. I believe it's what kept you from taking it out of Park unless your foot is on the brake first. Maybe it's the switch at the brake end of the circuit. Or the solenoid.
Old Mar 3, 2020 | 10:28 AM
KTM rdr's Avatar
Thanks, I've been doing a little research and that seems to be an issue with C4 auto's. I seem to remember hearing a 'click' when I put my foot on the brake and I'm not hearing that now.
Old Mar 3, 2020 | 11:43 AM
Good luck and let us know what you find.
Old Mar 31, 2020 | 12:16 PM
KTM rdr's Avatar
An update on this problem. Since we're all stuck at home I decided to take a look. Easy solutions first, took the center shroud off to check the shifter linkage and found a quarter floating around underneath. pulled that out, cleaned thing a bit and applied a little lube. Working fine now. Sometimes you get lucky and the easy solutions work. Now just need the chance to take it for a drive.
sb66
Jul 25, 2016 07:08 AM
evroosevelt@hughes.net
Aug 20, 2014 10:28 PM
horsepower10
Nov 8, 2007 05:58 PM
eggbutt
Mar 6, 2007 12:52 AM
mattdrag
Nov 15, 2006 12:27 AM
