94 electric short?
Old Feb 14, 2014 | 03:36 PM
braveheart3158's Avatar
Question 94 electric short?
SYMPTOMS
1-Battery dead
2-Interior lts stay on
3-Remove fuse for interior lights then horn stays on.
4- Remove fuse for horn.
5-Problem solved.
Have had the car for 2 years.
Before this latest problem:
1- From time to time the horn would not work if steering wheel was turned
2- Digital speedometer would stick time to time. Bang on dash wit fist would fix
3- Beep horn without ignition on, the security alrn goes on at the same time
Not sure if some or all of this stuff is related
I do have the shop manuals. Before I die into that, I was hoping someone would have some insight?
Thanks!
Old Feb 15, 2014 | 04:34 AM
hcbph's Avatar
Default Problems
To me it sounds like you have a short in your wiring. You need an Ohm meter and you know which circuits you pulled the fuses in, that's where I'd start.
Old Feb 17, 2014 | 06:33 AM
Thanks. Gonna wait or this weather to break a little. Right now the battery is not dying withy the 2 fuses pulled. I have a basic understanding of electric. But now sure how to start with the diagnosis. Use an ohm meter where? On the in and out terminals of the fuse holder?
Old Feb 18, 2014 | 10:05 AM
ZFound battery dead yesterday even with the 2 fuse pulled, LHinterior lts and horn. So i removed the other hatch lts and any other interior lt fuses. Jumped the battery and let run.
Anyone know of a good auto electric guy on Long Island?
riley6riley
Nov 20, 2007 07:21 AM
LT4Dave
Nov 22, 2006 06:01 PM
rjensen
Oct 20, 2006 01:43 PM
zo6r black widow
Nov 6, 2005 09:15 AM
jeepxj
Jul 5, 2005 07:09 AM
