95' always runs hot
would removing the thermoatat make the car run cooler???? I was talking to a guy with a 94 vette that always ran hot , he change a switch by the radiator so the fan runs all the time and stays cooler,, any one know what this is or how to do it?
What's the digital temperture? The analog gauge is not as accurate as the digital. Seems like the fans are operating ok.
There is a small access hole on the right side of the radiator shround. Look & see if the area is full of trash, etc.
I'd try a flush & fill & see if that helps. Maybe also pull the top of the radiator cover &
wash out the fins. There are lots of things you can do.
Donot run the engine without the thermostat.
Don't know if you have an owner's manual, so check this out.
http://corvette-world.com/1995-corve...ree-a-148.html
If not the trip monitor is located to the left of the DIC.
Hit the gauges button & you will get a readout for "temp"-"battery"-"Tranny" & "oil temp".
