VATS. maybe...
Old Mar 25, 2007 | 08:32 PM
motomaniac1988's Avatar
Default VATS. maybe...
Summer of 06, I had some electrical issues with my car. The guy I took it to also bypassed the VATS by putting in the resistor by-pass. I am having problems with my car and it intermittantly wont start. When it doesn't start, the security light stays on indicating that the VATS is engaged but I dont know ho this is entirely possible. What I want to do is completely remove the VATS so it can't fail. What is the best way to go about doing this. Can I reprogram the computer and tun the VATS off so it doesn't give me any more **** ****!?!?!?!?!?
symptoms: car intermittantly wont start
wait 10-20 minutes, starts up
turn off, and try to restart, sometimes it does, sometimes it doesn't.
(everytime it does not start, the security light in the dash is illuminated.)
1992 Corvette Coup, lt1, 98,000 miles, stock (ok, so i replaced the opti-spark with a unit made by MSD)
Old Mar 25, 2007 | 10:59 PM
Black86vette's Avatar
Default RE: VATS. maybe...
You can get the vats disarm box. Go too www.vatssucks.com for more info.[&:]
Old Mar 26, 2007 | 10:20 AM
LeesVette's Avatar
It could also be a bad resistor in your key. If you have another set of keys next time try the other key when it happens. Same scenario is going on with my car and one of my keys is bad.
Old Mar 26, 2007 | 04:03 PM
Im taking the car to a guy today who installed the resistor bypass. Hopefully, something is just loose and he can snap it back together or something. If its not, then I have no idea what Im gonna do....
Old Mar 26, 2007 | 10:11 PM
Tacky's Avatar
A lot of the time when VATS is bypassed they just twist the wires that normally go to the key around the wires from the resistor.
The resistor really needs to be soldered in place for the bypas to work properly.
03z0
Corvette C5 Z06
Aug 26, 2007 04:46 PM
Black86vette
Apr 3, 2007 10:45 PM
sean2e
Nov 15, 2006 01:44 PM
mikeith
Oct 19, 2006 03:40 PM
LLL
Dec 16, 2005 07:34 PM
