AC Problems, Roasting Alive! Problem Solved
Old Sep 18, 2007 | 08:29 AM
MikeC4's Avatar
Default AC Problems, Roasting Alive! Problem Solved
Hi All,
Well I now have AC again! After many hours under the dash trying to trace down my hot air problem with no luck I took a break and just started paging through my owners manual. In a small paragraph in the climit control section I found a line that said to reset the climit control remove #1 and #17 fuses for 15 seconds and reinstall. I did and low and behold the AC/Heater works normal again. For how long remains to be seem but, for now all is fine. I have to say that after diconnecting the battery several times working on other problems may have caused the problem, but who knows?!
Old Sep 18, 2007 | 01:30 PM
Default RE: AC Problems, Roasting Alive! Problem Solved
Thanks for posting this tidbit. No telling how many of us this will help. Mine is doing the same thing and I thought it was just centrifugal heat. I'm going to go do it right now. Thanks again. Don't forget the wave. Cheers.
Old Sep 27, 2007 | 08:10 PM
80strat's Avatar
The same thing happened to me with my 92 this summer but fortunately my wife read the manual thinking that I pushed the wrong button. Just like you said, it started working again. I wonder why this happens? It must be common, if its in the book.
Old Sep 30, 2007 | 10:10 AM
scooterman's Avatar
Apparently when you disconnect the battery it throws the climate control for a loop. it has happened to me twice, and after doing the reset thing it took a couple of drive cycles for it to work right again.
Old Sep 30, 2007 | 07:56 PM
80strat's Avatar
Nope, in my case I hadn't disconneced the battery. One day it workeda few days later whenI tried it, it didn't. Did the fuse trick and now it works.
MikeC4
Jul 3, 2008 01:29 PM
May 10, 2008 01:46 PM
MikeC4
Sep 14, 2007 06:41 PM
Black86vette
Jul 4, 2007 07:47 PM
kruser
Jun 18, 2006 02:39 AM
