air flow diagram for 86
Old Nov 19, 2008 | 06:29 AM
steelhorse's Avatar
Default air flow diagram for 86
HI,
I have an 86 with climate control. I can hear my fan running pretty good but I don't seem to get a lot of air out of the floor vents. I can press bi-level and a lot comes out of the top vents.
Is there a diagram of the vent system? I just want to see if everything is in the correct position.
thanks
Old Nov 19, 2008 | 06:37 AM
Default RE: air flow diagram for 86
You probably have a vacuum leak. The supply vacuum from the engine should be what the engine vacuum is. Usually, the defrost position is the "at rest" position. If the supply is good, you might have a leak at the selector vacuum switch, which is obsolete from Delco and from Chevy. I know, because my 86 has similar problems. I found one in a wrecking yard.
mypetu39
Jul 5, 2007 03:48 PM
repodude43
Mar 9, 2007 07:56 PM
liviz40102
Aug 14, 2006 04:20 AM
kvette
Oct 24, 2005 01:16 PM
PAULKR
Sep 11, 2005 05:49 PM
