Aluminum Heads vs. Cast Iron
Old Sep 17, 2006 | 01:15 AM
All2kool's Avatar
Default Aluminum Heads vs. Cast Iron
Were Aluminum Heads an option for the 5.7L TPI C4? Why do some C4's have them and others do not? What are the advantages of either?
Old Sep 17, 2006 | 01:44 AM
raisinbran's Avatar
Default RE: Aluminum Heads vs. Cast Iron
late 86 and on got the aluminum heads, as did all verts in 86. the aluminum heads gave 5 more hp.
Old Sep 27, 2006 | 06:15 PM
rwolak's Avatar
unfortunately, engines with aluminum heads and cast iron blocks have a habit of blowing head gaskets because of the difference in the coefficient of expansion for aluminum and cast iron. all this has to happen is once and you might be rebuilding your engine.
Old Sep 27, 2006 | 06:51 PM
All2kool's Avatar
Well, I'm glad I have Cast Iron Heads then. Thanks.
Old Sep 28, 2006 | 01:47 AM
raisinbran's Avatar
also the aluminum heads disperse heat better, therefore allowing the CR to be bumped up, not to mention they are lighter.
Old Sep 30, 2006 | 05:56 PM
d93vette's Avatar
was up, alum. heads are also ligther than iron heads.
Old Dec 22, 2006 | 12:11 PM
JoeVetteman's Avatar
Aluminum heads were standard on every L-98 starting in feb.'86.I guess some of the advantages are better heat dissipation and of course,less weight.Aluminum heads or not,the L-98 will always be one of the greatest Vette engines.Long live the C4!!!!! ('96 LT-1 man).
86IROCZ
Aug 1, 2007 12:59 AM
mypetu39
Dec 22, 2006 11:56 AM
chase sperry
Nov 26, 2006 12:31 AM
forango
Aug 4, 2006 06:13 PM
JimG
Jul 5, 2006 03:27 PM
