Amp guage bouncing
Old May 23, 2007 | 01:15 PM
AlfaDog's Avatar
Default Amp guage bouncing
Howdy All:
Still geting my '94 LT1 sorted out. The "problem de jour" is a flucuating amp guage. When driving during initail warm-up, I notice that my speedo LED display background will dim & brighten slightly as I drive - which seems to correspond to fluctuation from the amp guage: Backlite brightens - guage moves to about 14.5 - backlite dims - guage drops to 9-10 amps. After about 10 miles of driving , everyhting settles down. My initail thoughts were to check/clean batt. terms and alt. conn. - did that, no change. Any suggestions on where I go from here?
TIA - A.D.
Old May 23, 2007 | 06:48 PM
LeesVette's Avatar
Default RE: Amp guage bouncing
Mine does that when I turn on my turn signal indicators.
Old May 23, 2007 | 07:34 PM
78buckshot's Avatar
The voltage regulator is hunting, sounds like it's time to rebuild the alternator with new diode's, brushes, and voltage regulator which are all internal to the alternator, or just put in a rebuilt.
Old May 23, 2007 | 07:53 PM
Don't waste your time trying to rebuild. The voltage regulator is not doing the job and rebuilts are fairly cheap, just stay away from Autozone. Very poorly and cheaply done.
Old May 24, 2007 | 11:56 AM
AlfaDog's Avatar
Thanks, guys - the question got answered for certainon the way home last nite....gauge dropped to 8 amps and warning lites started popping on - was able to limp it home. Going with aOEDelco unit today.
Old May 27, 2007 | 08:59 AM
scooterman's Avatar
My alt is whining, holds at about 14 volts- I'm sure it's on its way out too. Love my vette, but it is going to 50 dollar me to death
Old May 27, 2007 | 11:39 AM
ORIGINAL: AlfaDog
Howdy All:
TIA - A.D.
Amp guages and volt meters are entirely different.
Are you sure what you have is an ammeter?
Old May 31, 2007 | 08:55 PM
AlfaDog's Avatar
Sorry, my bad []the VOLTAGE METER now reading 14 - 14.5 at speeds. Assume this is to spes.
-A.D.
Old Jun 1, 2007 | 06:43 AM
LeesVette's Avatar
Yes that is to spec.
nopiman
Dec 26, 2013 12:30 AM
Dinis55
Jul 17, 2011 05:33 PM
dheller1
Oct 24, 2010 01:14 PM
PTA
Oct 18, 2006 03:14 PM
Vet Head
Oct 31, 2005 02:17 PM
