Amp guage bouncing
Howdy All:
Still geting my '94 LT1 sorted out. The "problem de jour" is a flucuating amp guage. When driving during initail warm-up, I notice that my speedo LED display background will dim & brighten slightly as I drive - which seems to correspond to fluctuation from the amp guage: Backlite brightens - guage moves to about 14.5 - backlite dims - guage drops to 9-10 amps. After about 10 miles of driving , everyhting settles down. My initail thoughts were to check/clean batt. terms and alt. conn. - did that, no change. Any suggestions on where I go from here?
TIA - A.D.
TIA - A.D.
The voltage regulator is hunting, sounds like it's time to rebuild the alternator with new diode's, brushes, and voltage regulator which are all internal to the alternator, or just put in a rebuilt.
Don't waste your time trying to rebuild. The voltage regulator is not doing the job and rebuilts are fairly cheap, just stay away from Autozone. Very poorly and cheaply done.
Thanks, guys - the question got answered for certainon the way home last nite....gauge dropped to 8 amps and warning lites started popping on - was able to limp it home. Going with aOEDelco unit today.
ORIGINAL: AlfaDog
Howdy All:
TIA - A.D.
Howdy All:
TIA - A.D.
Are you sure what you have is an ammeter?
nopiman
Dec 26, 2013 12:30 AM
]the VOLTAGE METER now reading 14 - 14.5 at speeds. Assume this is to spes.
