Another newbee question?????
Old Feb 24, 2008 | 11:45 AM
dale's Avatar
Default Another newbee question?????
Should I buy a K&N airfilter, or a new airfilter system. Is it worth the money?
Old Feb 28, 2008 | 06:34 AM
RudeDog's Avatar
Default RE: Another newbee question?????
Clean/cool air is integral to your system. The more of both, usually the better.
I have a K&N air filter but have not installed yet. Doubt I will feel results but you know what
they say, it's all between your ears. Fairly cheap upgrade.
Old Feb 28, 2008 | 12:09 PM
Ric's Avatar
Ric
you didn't give the year of the Corvette so I will try. If you have aMAF system the computer will probably see the air increase and it will probably add fuel properly. If you have a MAP systemthe air flow is not measured directly but the computer estimates the airflow based on stock parts. Map equipped cars require alot more changing calibration at the computer. This is probably why you will see different results from different Corvette's on the forum.
hope this helps
Ric W.
Old Feb 28, 2008 | 07:30 PM
dale's Avatar
Sorry, I have a 1994 vette, I do not know which system it has.
thanks Dale
Old Feb 28, 2008 | 08:09 PM
Ric's Avatar
Ric
Dale the 1994 has the AC/Delphi MAF which would read direct measurement so you should be able to install the filter and probably notice some HP gain from more air. Good Luck
Old Feb 29, 2008 | 08:02 AM
dale's Avatar
Thanks, would you just go with a filter or a new air induction system?
Thanks
Dale
Old Feb 29, 2008 | 04:53 PM
Ric's Avatar
Ric
Dale personally I would go with just the filter but I am cheap. The induction system are high priced but they do soundgood and arenice looking. The MAF will compensate for ether. Dale its your call
good luck
Ric
svette
Jun 30, 2010 06:47 AM
dale
Mar 7, 2008 10:15 AM
clocknut
Jul 14, 2007 07:27 AM
1991 C4
Jun 20, 2006 01:13 AM
