Newbee help - just bought a 96 C4 w/97k mi - what should I expect re: service issues?
Old Aug 14, 2006 | 01:58 AM
jsjodin's Avatar
Default Newbee help - just bought a 96 C4 w/97k mi - what should I expect re: service issues?
I just bought a 1996 C4 w/97,000 miles. What should I expect as far as servicing i'll need to do right away (what typically breaks on these at this mileage?). i don't know what's been done throughout the history of the car. Anything you can inform me of will be greatly appreciated.
Was 1996 a good year for Corvette? The car is very clean.
Need some expertise from you experienced 'vette owners.
Thank you - John
Old Aug 15, 2006 | 02:18 PM
Silverbullet's Avatar
Default RE: Newbee help - just bought a 96 C4 w/97k mi - what should I expect re: service issues?
First of all the 96 was a great year for the C4. There isnt anything to worry about if you keep up your maintance. It sounds to simple because it is. If you just got the car, I would take it in for an engine flush and do your general servicing. Be sure to use Synthetic oil. Another thing I would do is put in a K/N filter. It will help the car breathe better. The only problem I had thus far was my headlight motor actuator. Dealerships will charge you an arm and a leg to workon it (whether replacing it or put bushings). If you need to ever get an actuator, get it from O'Reilly parts F.Y.I. It costs about $300. The dealership wants to charge you twice that. Well hope this helps. Enjoy the car and see you on the road!
Old Aug 17, 2006 | 02:09 AM
jsjodin's Avatar
Thanks Chad - I just took her in for smog. They found the battery was bad, and replaced a belt. Oil looks new so I think I'll leave it for a while.
She does need new rear tires. What do you run for tires? Are runflats necessary?
jonny5
Jan 15, 2009 10:50 PM
Corvette_Johnny
Corvette ZR1
Jul 10, 2007 07:30 PM
tcrote5516
Jul 22, 2006 01:01 AM
rjensen
Jun 17, 2006 08:54 PM
Genesis_26317
May 31, 2006 09:08 PM
