Battery dying on 85 Vette
Old Aug 3, 2009 | 08:06 PM
richardb9342's Avatar
Default Battery dying on 85 Vette
My battery drains overnight and there are times that it is fully charged but when you turn the key, you get a loud click and everything goes dead. Any thoughts?
Old Aug 3, 2009 | 10:09 PM
partsman41's Avatar
The loud click and everything goes dead sounds like a bad connection on a battery cabe. Could be either end of either cable. A battery on it's way out will act like yours,or if you;re certain the battery is good,pull all the fuses and replace them one at a time until you find the culprit,then fix whatever is shorted or grounded. Good Luck!
Ron
Old Aug 27, 2009 | 10:02 PM
86ITMAN's Avatar
Check your alternator, make sure none of your cables are broken or cracked. Had a similar problem on my 86.
Yellow Eagle
Feb 26, 2013 11:38 AM
Vette92
Mar 31, 2009 11:13 PM
dfwgsx
Feb 21, 2008 12:03 PM
jdeatsch
May 23, 2007 08:14 AM
MyC5WillEatYouAlive
Jan 19, 2007 09:08 PM
