Blower Motor continues to run on high speed even when ignition is turned off
Old Nov 29, 2006 | 05:42 PM
nickm's Avatar
Default Blower Motor continues to run on high speed even when ignition is turned off
I have an '88 with climate control. The Heater / AC Blower motor will only run on high speed - and continues to run on high speed even when car is turned off, and the key is removed from ignition. I have to unplug at the fan motor, or the blower motor will continue running on high speed, and drain battery. I was thinking the relay? Any suggestions?
Old Nov 30, 2006 | 12:56 AM
Default RE: Blower Motor continues to run on high speed even when ignition is turned off
You have a bad blower control module. Unplug the connector to the module and the blower will stop. The module is solid state with a transistor that is controlled by your a/c control head. Seen it and replaced lots of GM blower control modules on climate control units. [8D]
Old Nov 30, 2006 | 04:50 PM
nickm's Avatar
Thanks for the information- Does $525.00 sound right for the blower control module "Kit" as quoted by Chevrolet Dealer?
Old Nov 30, 2006 | 09:54 PM
Check with a local parts store that carries A/C Delco parts. The Delco will be cheaper than the dealer and yes, it is expensive. []
seminoleskid
Mar 6, 2009 03:15 PM
riohippy
Jan 25, 2008 09:22 AM
rjensen
Sep 5, 2007 10:22 AM
mcu643
Jan 6, 2007 11:48 PM
bertsbassbox
Jun 18, 2006 02:41 PM
