can i reused my block?
no problem,that block is good,the older the better,keep it.take to the machine shop and have them mike the cylenders and check line bore,and deck hight,then get some trick flow heads,and your stroker kit bring down to your machine shop for them to do it,remember this each cylender has to be notched out at the bottom for thr rod to clear .i have built a few 383's they make good torque.and top end.good luck....oh and if you bought the motor and did not hear it run have the block magnuflexed.
[IMG]local://upfiles/1664/FDE83F3DB64141938F9412C3499FCF26.jpg[/IMG]
ORIGINAL: corvette king
King is right, you will have to have the block notched for rod clearance with a stroker kit. Also, is your block a four bolt main? 2 bolt will work, but 4 bolt holds up better under higher horsepower and increased load.
WELL, THE MOST INPORTANT PART OF YOUR MOTOR, IS THE BOTTOM END,AND WHEN IT COMES TO STROKEING A MOTOR ,U BETTER NO WHAT U ARE DOING, WHAT U SHOULD DO IS HAVE YOUR MACHINE SHOP DO THE LOWER END,THATS JUST THE CRANK,ROD,PISTONS,RINGS,BERINGS,....THEN U CAN DO THE REST, .......REMEMBER THIS IF U PLAN ON BUILDING IT YOUR SELF AND RUNNING NOS YOU BETTER BUILD THR MOTOR LOOSE,AND HAVE TO CHECK WHAT GAP TO GAP THE RINGS ON THE PISTONS,U CHECK WITH THE BUISNESS U BOUGHT THE PISTONS FROM, AND IF U HAVE THE MACHINE SHOP DO IT LET THEM NO WHAT U PLAN ON DOING WITH THE ENGINE, NOS,,,SUPERCHARGER,,,,TURBO,,,ECT
[IMG]local://upfiles/1664/0B2CC09870264EA7855916DECE7ACE57.jpg[/IMG]
