can i reused my block?
Old 03-21-2006, 04:57 AM
raisinbran's Avatar
Default can i reused my block?
so i have decided to start planning for a 383. i have an 86 with about 67,000 easy miles on it. Is it safe to say i can reuse this block or should i look into 383 shortblocks?
Old 03-21-2006, 11:21 AM
Default RE: can i reused my block?
You should be able to reuse the block the machine shop will check it out when you get it bored. If you are going to use a eagle crank check it real close.
Old 03-22-2006, 12:36 AM
no problem,that block is good,the older the better,keep it.take to the machine shop and have them mike the cylenders and check line bore,and deck hight,then get some trick flow heads,and your stroker kit bring down to your machine shop for them to do it,remember this each cylender has to be notched out at the bottom for thr rod to clear .i have built a few 383's they make good torque.and top end.good luck....oh and if you bought the motor and did not hear it run have the block magnuflexed.
[IMG]local://upfiles/1664/FDE83F3DB64141938F9412C3499FCF26.jpg[/IMG]
Old 03-22-2006, 02:18 AM
raisinbran's Avatar
ORIGINAL: corvette king
I've heard many people say that. But i would like to build as much of the engine myself as possible 1. to save money and 2. because nothing compares to the feeling of satisfaction after you finish building something. I have good mechanical skills, but no experience with the bottom end of an engine. How parts do u think a machine shop should handle installing??
Old 03-22-2006, 02:35 AM
King is right, you will have to have the block notched for rod clearance with a stroker kit. Also, is your block a four bolt main? 2 bolt will work, but 4 bolt holds up better under higher horsepower and increased load.
Old 03-22-2006, 04:47 PM
WELL, THE MOST INPORTANT PART OF YOUR MOTOR, IS THE BOTTOM END,AND WHEN IT COMES TO STROKEING A MOTOR ,U BETTER NO WHAT U ARE DOING, WHAT U SHOULD DO IS HAVE YOUR MACHINE SHOP DO THE LOWER END,THATS JUST THE CRANK,ROD,PISTONS,RINGS,BERINGS,....THEN U CAN DO THE REST, .......REMEMBER THIS IF U PLAN ON BUILDING IT YOUR SELF AND RUNNING NOS YOU BETTER BUILD THR MOTOR LOOSE,AND HAVE TO CHECK WHAT GAP TO GAP THE RINGS ON THE PISTONS,U CHECK WITH THE BUISNESS U BOUGHT THE PISTONS FROM, AND IF U HAVE THE MACHINE SHOP DO IT LET THEM NO WHAT U PLAN ON DOING WITH THE ENGINE, NOS,,,SUPERCHARGER,,,,TURBO,,,ECT
[IMG]local://upfiles/1664/0B2CC09870264EA7855916DECE7ACE57.jpg[/IMG]
hester
12-06-2007 12:11 PM
jbrigman03
08-09-2006 12:18 AM
57halfton
03-23-2006 07:41 PM
DaveM
07-03-2005 03:19 AM
thirdtimevetteowner
06-06-2005 09:36 PM
Quick Reply: can i reused my block?
