cluster or charging issue
Old Jun 16, 2006 | 04:29 AM
bobbiebello's Avatar
Default cluster or charging issue
i have an 86 vette with 85,000 on the way home, the voltmeter started lighting up and my charge went to 9V. the lights became dim. it wont restart, so i got a new battery. now it starts but the charging light is slight up and reads from 11.0 - 11.6 volts. the tested the battery, with engine off...read 12V. started the engine, tested the batter, reads 14+. ive noticed that the water temp siwth and volt swich wont stay off. what gives here? any ideas
Old Jun 16, 2006 | 08:49 AM
Default RE: cluster or charging issue
The rectifier in the alternator is probably shorting out, either that or a coil winding is under heat. Very good chance your alternator is due to be replaced. [8D]
Old Jun 16, 2006 | 01:59 PM
yap...sounds like it...ill get the alternator tested or just replace it this weekend. ill keep you guys posted.
Old Jun 17, 2006 | 08:04 PM
replace the alternator with an ac delco...everything is now ok. the gauges...temp/off/voltmeter are now ok. the red light disappeared and i can see its now 14+ volts. thanks mech259
Old Jun 18, 2006 | 10:53 AM
NP, glad u got it going. [8D]
Tom donoghue
Feb 20, 2007 12:29 AM
rjensen
Nov 29, 2006 06:11 PM
rjensen
Aug 22, 2006 12:25 AM
rjensen
Aug 20, 2006 09:32 PM
GrtAmrTrkr
May 31, 2006 10:03 PM
