code 29
Old Nov 23, 2007 | 03:58 PM
dfwgsx's Avatar
Default code 29
hey guys alright the car was running perfect then next thing i know i start coming to a stop at a light and the engine starts lobing...well then the service engine light comes on. Well i hooked up a scanner to pull the codes and on my snap on it says: CODE 29 EAS ELECTRICAL FAULT. What exactly is this pertaining to? how can i fix this so i can get it back to the way it should be?
THANX MATT
Old Nov 23, 2007 | 05:25 PM
Default RE: code 29
Year model?
Old Nov 23, 2007 | 05:44 PM
ZR1clone's Avatar
Default RE: code 29
hey dfwgsx... I have a Haynes Repair Manual for 1984 - 1996 corvettes. I can not find a # 29 [&:]anywhere. Nope can't find code # 29. What year is yours?
Old Nov 23, 2007 | 08:29 PM
Viscount's Avatar
Default RE: code 29
Believe that code is for the airpump. At least for my 95. What year do you have?
Old Nov 25, 2007 | 10:52 PM
dfwgsx's Avatar
Default RE: code 29
a 1995...also the code i believe was 64 also popped up for my right bank O2 sensor running lean, how do i know which one is messing up considering there is a pre-cat and after-cat?
Old Nov 26, 2007 | 07:35 AM
Default RE: code 29
ORIGINAL: dfwgsx
a 1995...also ...right bank O2 sensor running lean,
Hmmm. O2 sensor indicating a high O2 content right bank?
Can't be fuel pressure, cause that would be common to both sides. Gotta' be an injector right side fault...
Old Nov 26, 2007 | 11:08 AM
dfwgsx's Avatar
Default RE: code 29
i just replaced them with 24lb motorcrafts, by chance do you think that the air pump could be causing it to lean out?
also what is the plastic ball that is next to the smog pump? I hit something on the highway and it ripped my inside fenderwell out as well as that ball. Is it okay to drive without it?
Old Nov 27, 2007 | 09:19 PM
Default RE: code 29
Quite possible. Unplug the air hoses to the exhaust manifolds and see if there is pumping @ idle. Shouldn't be and if it is one side (O2 side), then there's your problem.
Old Dec 3, 2007 | 03:40 PM
dfwgsx's Avatar
Default RE: code 29
is there anymore depth you can go on that sorry i dont exactly understand what you stated.
THANX MATT
Old Dec 3, 2007 | 08:11 PM
Default RE: code 29
Sure. You should have 2 air hoses off the smog pump, 1 to each exhaust manifold. Pull each off and see if air is being pumped at idle. It shouldn't be. If you do, then your diverter valve is bad, making one side read lean or even both sides, depending on if they are pumping. Should only be pumping under throttle.
