code 29
hey guys alright the car was running perfect then next thing i know i start coming to a stop at a light and the engine starts lobing...well then the service engine light comes on. Well i hooked up a scanner to pull the codes and on my snap on it says: CODE 29 EAS ELECTRICAL FAULT. What exactly is this pertaining to? how can i fix this so i can get it back to the way it should be?
THANX MATT
THANX MATT
ORIGINAL: dfwgsx
a 1995...also ...right bank O2 sensor running lean,
Can't be fuel pressure, cause that would be common to both sides. Gotta' be an injector right side fault...
i just replaced them with 24lb motorcrafts, by chance do you think that the air pump could be causing it to lean out?
also what is the plastic ball that is next to the smog pump? I hit something on the highway and it ripped my inside fenderwell out as well as that ball. Is it okay to drive without it?
Sure. You should have 2 air hoses off the smog pump, 1 to each exhaust manifold. Pull each off and see if air is being pumped at idle. It shouldn't be. If you do, then your diverter valve is bad, making one side read lean or even both sides, depending on if they are pumping. Should only be pumping under throttle.
