courtesy lights
Old Oct 1, 2007 | 08:52 PM
  #11
Default RE: courtesy lights
ORIGINAL: emd820
The courtesy lights don't come on under any circumstances. The lights on the mirror don't come on when the door is opened. They only come on with ignition on and you flip switch on the mirror.
My rear view mirror light is on low power all the time. Anybody else's???
Ya' gotta' find the common feed for the two courtesy lamps (unless you're lucky, and they're both burnt).
I don't think there's a relation between the mirror light, and the courtesy lamps. Possible, but I'm not knowin' it.
Start on the power source for the courtesy lamps. It looks like haynes diagram has the console glove box light on the same feed (but with a different ground) as the courtesy lamps. Does yours work?
Old Oct 1, 2007 | 09:38 PM
  #12
scooterman's Avatar
what about the bulbs?
Old Oct 1, 2007 | 09:44 PM
  #13
Okay, here we go.
The lights ain't gettin' power, or they ARE gettin' power, and thecircuit for both of them ain't groundin' out, OR BOTH.
According to this diagram, those two lights come on by the circuit groundin' out3 ways:
the headlight switch, the driver's door, or the passenger door - see thepurple circles. All 3 did not fail. If they did, buy a lottery ticket.
Both bulbs did not fail (did they?) Nor did the power feed for both fail. If they did, see an exorcist, cause according to the diagram, that 's impossible.
That leaves only one point where there's a common link - the blue/green circle. That HAS TO be where the break is.
[IMG]local://upfiles/5243/6DDC92A4E4CC49A28FAC3A4760AF0A45.jpg[/IMG]
Old Oct 3, 2007 | 08:33 AM
  #14
emd820's Avatar
Turns out that it was the fuse. Everything now works properly. Thanks to all for the help.
Old Oct 3, 2007 | 09:01 AM
  #15
rshiver's Avatar
ORIGINAL: emd820
Switch can't be at fault because the two lights behind the seats come on when the door is opened.
ORIGINAL: emd820
So thereare 2 fuses for the interior lights? One for the courtesy lamps under the dash, and one for the cargo area lights?
According to the wiring diagram cwb posted, there's only one fuse.
Old Oct 3, 2007 | 11:51 AM
  #16
emd820's Avatar
Yes thats true, that's why I never thought it was the fuse. When I pulled out the blown fuse, the cargo lights stayed on.
Old Oct 3, 2007 | 12:08 PM
  #17
rshiver's Avatar
Thats interesting.Either way, I'm glad you got everything working.
Old Oct 3, 2007 | 05:29 PM
  #18
ORIGINAL: rshiver
Thats interesting.
Yeah - sure is, 'cause I am now completely confused on how that worked out.
The wiring diagram is probably wrong - it's from the Hayne's book.
But still - two different fuses for interior lights???
kucinski
Feb 6, 2013 06:06 PM
kheel
Jul 23, 2010 10:56 AM
hedgehognj
Jan 17, 2009 02:26 PM
cjdietzman
Oct 18, 2007 10:21 PM
jadrfld
Feb 25, 2006 06:17 PM
