Cracked acrylic top can it be repaired?
Old Jul 15, 2007 | 07:30 AM
oldtvman's Avatar
Default Cracked acrylic top can it be repaired?
I have the dark blue acrylic top on my c4. It has two cracks in the front. I know that Eckers want about $1200 for a new top. Has anyone had any luck repairing these guys. It seems to me if you used resin and color die you should be able to fill the cracks, sand it and then buff if out.
Anybody every repaired their t top?
Old Jul 15, 2007 | 01:04 PM
Default RE: Cracked acrylic top can it be repaired?
ORIGINAL: oldtvman
Cyanoacrylate, and fiberglass powder, from sanding.
Get some wet or dry sandpaper (it doesn't break up into your powder), sand some fiberglass onto a clean surface, work it well into your carefully flared crack from the outside, apply the cyanoacrylate. Repeat for the interior, making sure to get the powder all the way into the crack, to meet the exterior-applied powder.
Buff and or clear coat. It can be done well enough to not be seen at all; it depends on purity of the powder, and saturation by the cyanoacrylate.
EDIT: cyanoacrylate is superglue.Similar compoundto your acrylic top.
Old Jul 28, 2007 | 09:14 PM
scooterman's Avatar
i fixed mine with jb weld and it looks pretty good
Old Jul 29, 2007 | 06:50 AM
I bought a reman top from a source that I will have to look up for my 86 for $500.00. Is your top see through? If so, you can't patch it. I don't know if a patch would hold very well considering the stress it is put through.
Old Aug 6, 2007 | 07:07 PM
84corvetteC4's Avatar
if you can do a really good job on it I would say go for it, the worst oyu can do it ruin it and then but a new one[:@][:@][:@]and 500-1000 is a steep price to not do a good job ...
Crash
Jan 2, 2012 04:12 AM
Catman87
May 17, 2008 05:23 PM
pewter2000
Sep 25, 2007 10:04 AM
TealC4
Mar 28, 2007 02:48 AM
Ed04
Dec 23, 2006 05:32 PM
