Cruise control removal ?
Old Apr 5, 2008 | 11:15 AM
91vetteny's Avatar
Default Cruise control removal ?
I removed the cruise control system from the car....Just unpluged , unbolted, removed throttle cable and t- off the vacuem line on the nearest vacuem line.....I didnt notice this before but when iam driving I hear a SSSSSSSing sound comming from the inside by the brake pedal when I apply the brake and the brakes get soft but they still work. Any clue what this is?
Old Apr 5, 2008 | 10:30 PM
Default RE: Cruise control removal ?
A failed brake booster diaphragm (which will allow a vacuum leak)makes for a HARD pedal. And you can hear the hiss ONLY when the pedal is pressed. That is, ONLY if the diaphragm is toast.
Old Apr 5, 2008 | 10:59 PM
91vetteny's Avatar
Iam not sure what you mean. The hiss comes only while applying the brake and the pedal starts to sag but not to the bottom. SO u think this as nothing to do with removing the cruise? Tjhe hissing sound is coming from in the car
Joe
Old Apr 5, 2008 | 11:05 PM
91vetteny's Avatar
Sorry Happy b0day and thanks
Old Apr 6, 2008 | 02:48 AM
ORIGINAL: 91vetteny
Joe
If it hisses when you press the brake, the booster is probably bad. IF that's what's wrong with the brakes, I don't think it's related to the cruise disconnection.
Although both use vacuum, if vacuum routing is now incorrect, it might cause power brake problems gettin' vacuum, but it would NOT cause a hiss at the booster.
LS77L82
May 16, 2007 03:25 PM
mraaron895
May 14, 2007 03:35 PM
95trplblkandtan
Jan 16, 2007 01:14 AM
harleyboy52
Dec 17, 2006 12:04 AM
knob
Jun 16, 2006 09:56 AM
