electrical fuel problems
Old Jan 15, 2010 | 06:39 PM
BlackC484's Avatar
Cool electrical fuel problems
I own an 84 corvette coupe cross fire injection ( JUNK ) it just died on me i got it home has a spark but not gettin fuel at all . I checked the pump it was good checked the relay also good.I checked the fuel pump fuse NO POWER but fuse is good so i ran a wire from my battery to terminal G under my dash fuel pump kicked on and had power to the fuse i was happy until i tried to start it HAHA.No fuel came out of the injector i cracked the line fuel came out just fine .... Can anyone PLEASE help me im pretty much lost ....
Thanks
Spencer
Old Jan 15, 2010 | 07:26 PM
partsman41's Avatar
I'm not very sharp around this stuff,I'm stuck in the carburetor days.but...................... if I were to guess I would think you're not getting power to the injectors? Don't somebody make a gadget that plugs in there somewhere and blinks when the injector gets a signal? Could this be done with maybe a dvm?My 84 had the "dies" for awhile and then would start right back up. After this act for a few times it wouldn't start back up. I replaced the ECM which I had got off fleabay and that was the end of the problem,it's been a couple of years now. There were other issues prior to the final "die" and no trouble codes so I was pretty sure the ECM was on it's way out. Good Luck!
Ron
Old Jan 15, 2010 | 09:59 PM
BlackC484's Avatar
Ooo ok thanks man ill get a test ran on it first find out what the deal is i just put a new rear end in the car 3 weeks ago and now it just died on me and wont start back up .
Old Jan 18, 2010 | 06:17 AM
First you need to check to see if you have power to the 2 injectors. Since you have spark, that means the ECM is seeing a pulse from the ignition module. You either have no power to the injectors or lost the ECM.
Old Jan 24, 2010 | 10:25 PM
tomwillie84's Avatar
Default Electrical Fuel Problem
You might want to check the fuses for the injectors first. Sounds strange that both are out at the same time but it may indicate a common problem.
cbc5vette
Sep 25, 2006 10:59 AM
CORVETTE LADY
Aug 18, 2006 11:06 AM
slvrblt
Jun 1, 2006 09:10 PM
jefftwilley
Dec 9, 2005 12:11 PM
quasarfantasy
Aug 5, 2005 02:45 PM
