electrical fuel problems
I own an 84 corvette coupe cross fire injection ( JUNK ) it just died on me i got it home has a spark but not gettin fuel at all . I checked the pump it was good checked the relay also good.I checked the fuel pump fuse NO POWER but fuse is good so i ran a wire from my battery to terminal G under my dash fuel pump kicked on and had power to the fuse i was happy until i tried to start it HAHA.No fuel came out of the injector i cracked the line fuel came out just fine .... Can anyone PLEASE help me im pretty much lost ....
Thanks
Spencer
Thanks
Spencer
I'm not very sharp around this stuff,I'm stuck in the carburetor days.but...................... if I were to guess I would think you're not getting power to the injectors? Don't somebody make a gadget that plugs in there somewhere and blinks when the injector gets a signal? Could this be done with maybe a dvm?My 84 had the "dies" for awhile and then would start right back up. After this act for a few times it wouldn't start back up. I replaced the ECM which I had got off fleabay and that was the end of the problem,it's been a couple of years now. There were other issues prior to the final "die" and no trouble codes so I was pretty sure the ECM was on it's way out. Good Luck!
Ron
Ron
First you need to check to see if you have power to the 2 injectors. Since you have spark, that means the ECM is seeing a pulse from the ignition module. You either have no power to the injectors or lost the ECM.
