Engine overheat 90 c4
Old Aug 22, 2020 | 10:31 AM
Roger Freeman's Avatar
Default Engine overheat 90 c4
Overheating problem has been corrected
Last edited by Roger Freeman; Sep 20, 2020 at 08:34 AM. Reason: Problem has been corrected thank you everyone
Old Aug 24, 2020 | 12:32 AM
The only thing I would try would be to jumper 12 volt straight to the fan after removing the existing connector so you don't back feed into some other circuitry.
PS: punctuation makes things easier to understand.
Old Aug 27, 2020 | 06:54 PM
coupeguy2001's Avatar
Default Fan
What i did was to add wire and a relay.
solder a wire to the compressor 12v wire, then coat that with gasket sealant like “the right stuff” or ultra black.
on the power steering reservoir, there is a clamp around the middle.
change the screw, and mount a black 30 amp relay with the relay tab, then put the wire u just made to one of the the relay coil blades.
then ground the other coil blade.
Then add a # 12 gauge wire to the alternator battery stud.
make it 6” long and splice in a fuse holder that can handle 30 amps. Put in a 15 amp fuse. (The fan will use 12-13 amps but with electrical, overkill works a long time.) Then Add enough wire so u can put that to one side of the relay contacts (power).
then the last Lug of the relay, put it to the fan 12 v input.
then ground the neg side of the fan.
So when air is on, fan is running.
so if your wires short out or fan siezes, it just blows fuse.
Old Aug 28, 2020 | 01:25 AM
Sounds good.
KoolKell
Aug 15, 2020 01:08 PM
GT2Race
Aug 24, 2013 08:26 AM
mikenann
Jun 13, 2008 12:33 PM
khaki1967
May 15, 2007 10:06 PM
khaki1967
Jan 8, 2007 08:19 PM
