Engine cooling fan
Old May 15, 2007 | 08:43 PM
khaki1967's Avatar
Default Engine cooling fan
I know there have been many posts regarding the higher temps that these LT1s tend to run at. I recently had my radiator/engine flushed and any debris removed to help cool it down. Though it runs a little cooler, my mechanic suggestedwiring the fan to stay on while the car is running no matter what temp. Not sure if this is a wise move or not. I would be too concerned that the fan would burn out a lot sooner than if it turned on at 228 degrees (normal operation). On the postive side it would run much cooler when idling, which is when it really heats up. What do you think?
Old May 15, 2007 | 10:06 PM
vrooomm's Avatar
Default RE: Engine cooling fan
A.-get another mechanic.
B.Make sure everything is as good as it can be--clean rad,good belts etc.
C.Buy the remote switch from ecklers or midamerica and take charge of your fan!!
oldtvman
Sep 21, 2012 07:29 AM
ru10707
Aug 28, 2007 06:46 PM
jpflhr
Aug 18, 2007 08:30 PM
sam
Aug 27, 2006 05:46 PM
Bagpipingjake
Aug 21, 2006 11:20 PM
