Engine problems
Old Aug 25, 2006 | 08:49 PM
edge56's Avatar
Default Engine problems
I have a 95 Corvette that is giving me a fit. It started with O2 Sensors going out and then the Computer. Had all of that fixed and then one of the new sensors went bad upon changing it the engine spits and putters until you floor it then it runs good. When idling it shuts off. Tried new sensors and still the same problem. Put the old sensors in the car runs but service engine light come on. Does anyone have a clue as to were I can start looking to solve this problem?[&o]
Old Aug 25, 2006 | 09:16 PM
Red89vette's Avatar
Default RE: Engine problems
By chance have you checked the Air flow censor? If i'm not mistaken when the car is at wot it goes into closed loop on the computer, when in open loop it could throw a code on the computer.
Old Aug 26, 2006 | 10:31 AM
Without scantool readings, it's gonna be difficult to determine your problem. Several factors can contribute to the condition you are describing. Ignition timing, coolant sensor, Mass Air flow, MAP sensor, vacuum leak, injector clean, and so forth. How does the engine start and idle cold? If you have cold start idle probs, I would lean towards MAP or MAF sensors, because that's mainly what the computer looks at on cold start idle. Good Luck. [8D]
Carolina Mike
Jul 13, 2012 07:41 AM
Maytes
Jun 22, 2007 08:18 AM
g and k vette
Sep 19, 2006 09:45 AM
johngarrison
Jul 18, 2006 08:57 PM
johngarrison
Jul 11, 2006 07:08 PM
