Fuel injector replacement
Old Apr 29, 2007 | 03:56 AM
88RHVette's Avatar
Default Fuel injector replacement
I have at least one leaking injector on my 88 Vette. I have a chance to get 8 NOS injectors, number 5235211, at a good price. All the research I've done on the Internet indicates that these are for an 86 Vette and that the 87-88 Vette used 5235302. The flow rates are listed as the same (21.6 lbs/hr) at 43 PSI fuel pressure. The 5235211 has a plastic tip and the 5235302 has an aluminum tip. Also, the 5235211 is listed as low impedence while the 5235302 is listed as high. I think the 5235302 injector replaced the 5235211 and was used in older Vettes as a replacement for failed injectors. Does anyone know of any reason I couldn't use the 5235211 in my 88? Thanks in advance.
Old Apr 29, 2007 | 10:21 AM
Default RE: Fuel injector replacement
I am not sure about the difference in impedance. It all depends on what the quad driver in the ECM is designed for. In 88 as with all the L98's, the injectors fire left bank, right bank. They are not sequentially fired like the LT1. Might need to do a little more research on that impedance thing. The L98 uses the 22lb injectors in stock trim with operating fuel pressure around 35lbs @ idle.
Old Apr 29, 2007 | 10:38 AM
88RHVette's Avatar
You're correct about the impedence. I was off by one line on the chart I was reading. They're both high impedence injectors. Thanks.
Old Apr 29, 2007 | 12:26 PM
Black86vette's Avatar
People reccomend the Ford SVO Injectors....I heard accel are easily bad out of the box and leak...Just what I heard though. No experience with either one.
Old Apr 29, 2007 | 03:40 PM
LeesVette's Avatar
ORIGINAL: Black86vette
I have heard all the same things you posted. I would look into SVO injectors also, thats what all the people I know who have had to do an injector replacement have used. They all have LT1's though.
Old Apr 29, 2007 | 05:30 PM
Works well on the L-98s too.
Old Apr 29, 2007 | 09:19 PM
I have the 351 injectors in my 86 now. Same identical injector, just has a Motorcraft part# on it.
redvet
Jan 3, 2007 09:35 AM
halbert
Nov 2, 2006 10:14 PM
halbert
Nov 2, 2006 01:38 AM
arbasica
Sep 15, 2006 07:51 PM
ssa919
Jul 14, 2006 09:35 AM
