Fuel Pump Replacement
Old Jan 23, 2007 | 12:45 AM
94blackC4's Avatar
Default Fuel Pump Replacement
Does anyone have detailed directions for fuel pump replacement? Thanks!
Matt
P.S. - If you couldnt tell, its a 94 LT1
Old Jan 23, 2007 | 02:21 AM
Default RE: Fuel Pump Replacement
Well if it's the same as my '87 you remove the fuel door with the correct torques driver, carefully remove the rubber spill tray. remove the 11? bolts that hold the fill/ sending unit/ and pump in place, disconnect the hoses(3?),very carefully, holding the fill neck/sending unit /pump, liftstraight up until the float reaches the top. gently maneuver the unit to clear the float without bending the float arm and viola, you have just to follow the instructions included with the pump now and replace the unit in reverse of taking it out. good luck
PS: should take all of 15 min.
Old Jan 23, 2007 | 08:05 AM
94blackC4's Avatar
Thanks George! I am hoping to get a new one soon because my hard starting problem is caused by the fuel pump. Thats what i was told by a very good mechanic anyway.
Matt
Old Jan 24, 2007 | 01:19 AM
I've had my '87 for 6 months and had to do it twice. easy but frustrating. Good luck with it Matty. Cheers
vaelon
Aug 11, 2015 09:05 PM
slayerz06
Feb 10, 2009 10:48 PM
jack5995
Nov 13, 2005 10:09 AM
Blemons
Oct 4, 2005 12:51 AM
pbetts
Sep 2, 2005 10:19 AM
