hard starting when cold
Old Jan 19, 2007 | 04:14 PM
88redvette's Avatar
Default hard starting when cold
I,am a weekend driver of an 88 corvette so the car pretty much sits all week,but after it sits for a long time 2-?? days it is hard to start but as soon as it starts, and if you shut it off again it will first crank there after just woundering if anybody had any comments
Old Jan 19, 2007 | 05:29 PM
toml14's Avatar
Default RE: hard starting when cold
You may want to put a fuel pressure gauge on it and see if it is holding good fuel pressure while turned off. If the fuelpump is getting weak it will gradually bleed off fuel that is in the lines back to the tank. Thus after sitting for lengths of time the car must pump fuel all the way back to the intake.
Never had the problem on a vette but have had several GM trucks with that problem. Hope it helps !!
[/align]
Old Jan 19, 2007 | 08:42 PM
BluBeaSSt's Avatar
I have that fuel problem on my bird, what fixes it and before you start it let the key sit on the "on" postion for about 45 seconds wile the pump activates
Old Jan 19, 2007 | 09:54 PM
88redvette's Avatar
I had the fuel preasure tested last summer the mechanic said it was where it should be, but is it possiblethat it would still leak down if your pump is producing the presureyou need?
Old Jan 19, 2007 | 10:15 PM
toml14's Avatar
It is very possible. The last truck I worked on was a 98 GMC Sierra. The truck had to be started with starting fluid for weeks, but it would run perfect once started. Eventually the pump gave up and not even starting fluid would crank it up. By the way starting fluid is not a great idea touse often.Eventually it takes its toll!!
[/align]
Old Jan 20, 2007 | 06:32 AM
Can't remember if an 88 has a cold start injector, but if it does I would look in that direction first. You might have a thermotime switch that is bad. Thermotime switch is in the front of the intake manifold pointing at the radiator. [8D]
Old Jan 20, 2007 | 12:15 PM
94blackC4's Avatar
I just got back from getting my car tuned today, and I have the same problem. It was addressed at my tune and the mechanic said that it is more than likely my fuel pump. Its just old and giving out. Which, I have a 94 and if mine is going out, it could be quite possible that your 88 is biting the dust as well. I looked up prices and I dont remember but it didnt seem too expensive.
Matt
Old Jan 20, 2007 | 01:37 PM
88redvette's Avatar
well it sounds like i should replace the fuel pump exspecially if it inexpensive, it may be a quick fix to my problem. thanks for the info 94black c-4
Old Jan 20, 2007 | 05:35 PM
94blackC4's Avatar
I woudl definately get it checked out though. I dont want to be the one responsible for you spending money you didnt need tooin caseour two cars are different .
Matt
imb1987
Nov 13, 2010 01:08 AM
amvette
May 3, 2007 07:53 PM
Curious George
Apr 16, 2007 12:15 AM
fille9
Sep 27, 2006 06:27 PM
Doctor K
Jun 28, 2005 03:13 PM
