Headlight doors lower but will not raise.
Old Jan 3, 2007 | 01:05 PM
palmbayvette's Avatar
Default Headlight doors lower but will not raise.
Last night I turned on my headlights but the motors did not come on to raise them,Iturned them up by hand fine but when I turned off the lights they lowered normaly.I tried repeatedly but the motors only run to close the doors,no sound from them when trying to open. Thanks for any help.
Old Jan 3, 2007 | 02:19 PM
Default RE: Headlight doors lower but will not raise.
What year model? Could be the isolation relay or the headlamp switch. [8D]
Old Jan 3, 2007 | 02:30 PM
It's an 1989 coupe.I took the headlight switch apart to check for corrosion or burn marks but it looked good.I did not know if the headlight actuator module has gone bad because after raising the headlights manually they lower fine by the switch.
Old Jan 3, 2007 | 09:45 PM
Black86vette's Avatar
Mine pulled this bull**** last night. Cept only the passenger side wont come up....The drivers side works normally. Wtf is going on......Ugh. Tired of this stuff happening. Its something all the time. Cant the **** thing just be normal and STOP BREAKING.
Old Mar 22, 2007 | 06:08 PM
mafulton's Avatar
Had the same problem with my '89 coupe. Needed to have the headlight motor rebuilt. There's a guy on ebay who will rebuild yours for about $50 if you ship it to him. Works like new now. Good luck
Old Mar 23, 2007 | 08:41 AM
mypetu39's Avatar
MECH259, I've been meaning to ask you about these headlight operating problems. It took me three years to learn that when you turn out the lights on my 87 Vette, I had to gently push in the **** of the switch further, after turning off the lights,to get the headlamps to go down into the body of the Vette. I have to do this procedure all the time; is this normal for all Vettes, or simply the switch I have in my Vette?
mypetu39
Old Mar 23, 2007 | 09:35 AM
Mine doesn't do that, it must be the switch. [8D]
deansreef
Mar 23, 2007 11:56 PM
ernie22golf
Dec 27, 2006 06:47 PM
00camaro16
Dec 2, 2006 03:25 AM
00camaro16
Nov 2, 2006 11:30 AM
7771994AZ
Aug 1, 2006 10:59 PM
