i just put in new heater core !$#@&*
Old Jan 12, 2009 | 08:44 AM
xfasteddiex's Avatar
Default i just put in new heater core !$#@&*
i know why the chevy house wanted to charge 10 hours at $90.00an hour& labor book only calls for 5.5 .what a pain in the a$$ i wish i would have took some picsbut i was to busy.
now lights behind my tack & gueges dont work. speedo & a/c &trip monotor lights all work .i made a jumper wire hot wire ofa/c pannel lights to tach & guage lights they all work now . also cooling fans not comimg on . there is power all the time to both relays except whenthe key is off but no ground . so i made a ground wire from relay to ground so fan comes on when key is on .it has had this problem for a fewdaysbefor i put heater core in . any ideas what it could be ? i know its not getting groundbut does the computer turn on a ground relay tocomplete circut .
Old Jan 12, 2009 | 10:28 AM
Viscount's Avatar
Default RE: i just put in new heater core !$#@&*
If that's your helper at the bottom of the picture? He looks Ticked off!
Old Jan 12, 2009 | 12:33 PM
yes that is my youngestboy yogi bear
Old Jan 13, 2009 | 07:43 AM
partsman41's Avatar
Isn't there a major ground point in the right hand kick panel right near the heater? Looks like you'll have to keep checking grounds until you find it?
Ron
Old Jan 13, 2009 | 09:26 AM
ill check on that ground point thanks for the tip
Eddie
C3 Starship
Nov 19, 2007 06:42 PM
marinegene
Dec 30, 2005 09:35 PM
marinegene
Dec 29, 2005 07:20 PM
faleure
Nov 26, 2005 03:46 PM
rolliq
Oct 3, 2005 01:25 PM
