irratic idle
Old May 13, 2007 | 09:05 AM
scooterman's Avatar
Default irratic idle
After driving about an hour, at a stop light I noticed the car trying to take off by itself, I thought maybe i had my foot on the gas at the same time as the brake, so at the next light I watched the tach, and it went a little eratic and jumped up to about 1000, held for a second and went back down. the ac was off. It has done it about 5 times and hasn't set a code. It seems like i hear a relay sound from under the hood when it happens but I'm not sure. I'm thinking either the iac is going bad or tps. Any ideas?
Richard
Old May 13, 2007 | 05:24 PM
Black86vette's Avatar
Default RE: irratic idle
Vacum leak? Reset the IAC? Clean out the throttle body?**very bad issue for me YUCK**
Old May 13, 2007 | 09:51 PM
I think Blackies's right about the vacuum leak. TPI is bad for it. I'm surprised it has not yet triggered a 32 code - EGR - which gets purged about every 10 minutes. Failure to hold vacuum will trip the 32.
How many miles on the motor?
Old May 14, 2007 | 06:45 PM
scooterman's Avatar
about 110k
Old May 14, 2007 | 07:42 PM
Sticking pintle in the IAC is possible. TPS? I bet not, since you say it 'loped', as opposed to constant increase rpm's. My $$$ is on an intake leak somewhere between the TB and the intake manifold...
It's a pain replacin' the intake gaskets, but cheap.
acossey
Oct 4, 2019 01:25 PM
scotth48
Oct 17, 2008 02:35 PM
scotth48
Sep 23, 2008 06:25 PM
dan murphy
Oct 19, 2005 10:01 PM
radar
Sep 15, 2005 10:15 PM
